Displaying classes in hierarchical order
Classes can have compound names with up to four parts, separated by a dash, to create a hierarchical structure. Each name part is a different level in the structure; for example, in the name "Arch-Wall-Ext", "Ext" is two levels below "Arch". Vectorworks can display class lists with or without the hierarchy. When hierarchical display is enabled, each level can be expanded or collapsed as needed. The image below shows a hierarchical (left) and non-hierarchical (right) display.
Non Plot classes are indicated by the red printer icon, but only for individual classes, not group headers.
A: Group header (expanded)
B: Subgroups
C: Group header (collapsed)
Hierarchical display is enabled differently and expands/collapses differently, depending on where the class list is.
Hierarchical display in pop-up menus
To enable hierarchical display, on the Session pane of the Vectorworks Preferences dialog box, select Display classes in pop-up menus hierarchically. This setting controls class pop-up menus throughout the software—for example, in the View bar and Object Info palette.
Select Preserve expanded/collapsed state of classes on the Session tab to maintain the expanded/collapsed state of the class list between uses.
Hierarchy section
Action to expand the section
One level below the group header
Click the disclosure arrow to the left of the group header
Double-click the group header
All subgroups of a group
Option-click (Mac) or Alt-click (Windows) the group header
All subgroups of all groups
Shift+Option-click (Mac) or Shift+Alt-click (Windows) any class
Hierarchical display in the Organization dialog box and Navigation palette
To enable hierarchical display:
Organization dialog box: Click the toggle button in the lower right corner, or select Hierarchical Display from the context menu.
Navigation palette (Vectorworks Design Suite product required): Select Hierarchical Display from the main menu or context menu.
Hierarchy section
Action to expand or collapse the section
Option-click (Mac) or Alt-click (Windows) the disclosure arrow of the group header
Option-double-click (Mac) or Alt-double-click (Windows) the group header
Shift+Option-click (Mac) or Shift+Alt-click (Windows) any disclosure arrow
Shift+Option-double-click (Mac) or Shift+Alt-double-click (Windows) any group header
Alternatively, select Expand All or Collapse All from the context menu.
To quickly assign the same visibility setting to all subgroups of a group, select a visibility setting for the group header.
When classes are displayed in hierarchical order, the class list's sort key and sort order cannot be changed.
The Organization dialog box
The Navigation palette
Concept: Classes overview
List box functionality
